zetec 45 dcoe carbs megajolt maps
Hello
Sorry for my English I am French.
I'm looking for maps for my zetec 2.0 blacktop dcoe 45 carbs mounted in my Sierra(the engine is not modified except for the carbs).
I use a megajolt ecu with a map sensor.
Can you help me?
Re: zetec 45 dcoe carbs megajolt maps
I don't have any Zetec maps but I think you better switch to TPS when you got 2x Weber 45 carburators. The map signal is going to be very weak. You can connect all 4 inlets but you will have to fit very small connections or one cylinder is fooling the other. Something like 1mm restrictors.
Tags for this Thread
