XE <> Type 9 friction plate - Part Number / size
Just trying to track down a clutch friction plate for use with the standard XE cover / Type 9 input shaft
The flywheel is now the flat type
I know its 1" x 23 spline
I have read through the archives and a 2.3 Diesel friction plate seems to be mentioned quite a bit, does anyone know a part number or the specific year / details / diameter I need to be sure I am ordering the correct part.
The cheapest friction plate SBD list is £116 + vat, but they have both 215 and 228mm - do both fit inside a standard XE cover? - what diameter is the 2.3 Diesel item?
QED list a heavy duty 228mm item for £68 + vat
http://qedmotorsport.co.uk/qed-shop/...pline-ford-box
Or are these just std Diesel plates with a hefty markup
Re: XE <> Type 9 friction plate - Part Number / size
Yeah, STD diesel plates.
Go for the 228mm if your using an LSD
Give these a try i think you can get a ceramic plate for about £150
http://www.questmead.co.uk/
I've bought one at Helix, they have them the right size for the vauxhall
wheel and T9 centerpiece.
