Help lhd mk2 pinto conversion
Hello gathering bits as doing pinto swap next week (yikes) on my lhd
Got engine and t9 bellhousing
Any issues ie will I need a lhd or Rs bellhousing
Anyone actually got a mk2 lhd pinto and can confirm clearances as set to swap next week
Had lot of input ie oh it be tite and may work
No good when up on ramp
Appreciate any advice ta
Re: Help lhd mk2 pinto conversion
RS bellhousing are the same, just the spigot is the other side for clutch fork.
But sump are different.
different sump is presumably because the sump retains the clutch cable outer
exact, cable and starter is opposite way from uk car.
But Onyd has kept some RHD car setup for LHD car, just made a longer clutch cable, and it works.
LHD RS2000 sump are difficult to source these days.
The Following User Says Thank You to Mkdu For This Useful Post:
Hello many thanks this is a great help appreciated
Was suggested transit clutch cable
It's happening this thursday so let you know how get on
