Results 1 to 8 of 8
Thread: Pinto running rough when cold
    Spanner Monkey Rs21968's Avatar
    Jun 2012
    West Yorkshire
    242
    I haven't been running my escy over the last few years but I do
    Start it every few months. The thing is when I do start it, it takes ages to start running on 4 cylinders.Once its warmed up it starts slowly running on four.Then after about 15/ 20 mins its settles down.
    I have one of those acuspark ignitions.Could that be failing?
    Cheers Chris
    3,242
    Re: Pinto running rough when cold
    Potentially fouled plugs - may get hot but its ain't burning off the cold rich idle mixture off. Plugs these days don't tolerate fouling like they used to. Best warm up is over a few miles of use - gets everything hot.
    9,208
    how old is the fuel ? unleaded degrades.
    Jun 2012
    West Yorkshire
    242
    The fuel is a few months old.I had another set of newish plugs so I put them in the summer when it was doing the same thing.
    9,208
    points or electronic ign ?
    maybe after its been stood a while , remove coil lead and crank it over a bit.
    then remove plugs and see if one is fouled up - im thinking valve stem possibly ?
    in reality if its being left for extended periods its more or less normal .....................
    Jun 2012
    West Yorkshire
    242
    Took plugs out cleaned them and put some fresh fuel in and it wont start at all.Fires here and there but thats it.
    Just going to have to replace everything leads plug cap etc.
    It has one of those acuspark conversions that I put on.Just wandering if thats failing.
    Aug 2015
    Leeds
    767
    What carbs are you running? Do you use a choke to start it? My pinto runs rough if it’s left stood until it’s warm, also it doesn’t like been left idling for a long time like at its mot, where it fouled a plug,
    Where do you keep it? Warm cold etc could be condensation on a plug lead, do you know which club set is off when it’s cold?
    Jun 2012
    West Yorkshire
    242
    Quote Originally Posted by Warrior View Post
    Just a standard 38 Webber.
    She has never not started properly over the 15 years I have had it lol.
