2 litre pinto inlet port size for 190 hp
Hi all can some advise me for a 190hp 2 litre pinto what size inlet port runners need to be and size of port around near where valve steam is or across short turn cheers mario.
Re: 2 litre pinto inlet port size for 190 hp
Steve Vizards book is a good place to start with this info
Matt
there is no "size" needed for 190bhp, in fact you dont want to open the port up, its about shape
Hi graham I've got a normal pinto head not injection what shape should I aim for advice please cheers mario .
Apple shape if I remember correctly. Read this book, very interesting. He built a 200+ pinto in the book IF my memory is correct. https://www.amazon.co.uk/How-Modify-.../dp/0863430856
I do not know why the links fail.
”How to modify Ford SOHC engines”is the book title. Author; David Vizard.
or you go the other way and lower the port near the short turn, seeing as most of the air goes straight across the back of the valve, lowering the port gives less of an obstacle to the incoming mixture. this work well with lots of valve lift and duration
