Results 1 to 8 of 8
Thread: Mk 2 escort winscreen washer relay
    May 2016
    lanarkshire
    Does anybody have a diagram that shows windscreen washer relay wiring in relation to the Wiper motor and switches. How many terminals does the wiper relay have (is it just a normal relay) Loom has relay holder (well I am sure it is for intermittent) but no relay present stalk has intermittent on it so may as well use it,
    May 2016
    lanarkshire
    Re: Mk 2 escort winscreen washer relay
    nobody any info ref wiper motor intermittent relay
  3. The Following User Says Thank You to bigbry For This Useful Post:
    Jun 2004
    Bristol
    1,494
    18
    It's the red one in this picture and has a built in delay for the intermittent wipers
    It's normally clipped to the reinforcement plate from the bulkhead to the steering column, up behind the instruments
  5. #4
    May 2016
    lanarkshire
    cheers Gavin do you have a wiring diagram Haynes Manual does not show these in wiring diagrams
  6. #5
    Jun 2004
    Bristol
    1,494
    18
    No, only got the Haynes diagrams myself. If your loom has the black relay plug, then plug in the right relay and it should work !
  7. The Following User Says Thank You to GavinR For This Useful Post:
  8. #6
    May 2016
    lanarkshire
    cheers Gavin it has the black relay plug problem is that it was a project rally car I bought and the loom can I say was in bits and just trying to piece it back together and not to sure where wires went. Also got the issue as Haynes manual has old wiring colours and car is a late model so believe late models had different coloured wiring
    is it just a std intermittent relay that goes in there
  9. #7
    Jun 2004
    Bristol
    1,494
    18
    I would have thought you could find a matching red relay on ebay, maybe from a later ford
  10. #8
    4,889
    What colours of wire do you have?
