Results 1 to 7 of 7
Thread: Hello anyone Id this gearbox please
    Oct 2018
    South wales
    Bought a pinto and box after wanted ad
    Told came out as is motor boiled and bellhousing wrong told v6 should have checked but there you go since found correct bellhousing is this box going to be any good ie ratios will output shaft length mean odd length prop for diff and will spline be different
    Oct 2018
    South wales
    Re: Hello anyone Id this gearbox please
    Won't let me add photos
    Casting no 8391 7006
    Jan 2008
    Up the garage
    2,775
    218
    Use the "uploader" tab for photos - it's easy.
    Oct 2018
    South wales
    Hello tried I'm poo with pc what is that tab icon
    What's opinion on t9 v rocket box
    3,236
    No such thing as a 'Rocket box' - There are 'Rocket Ratio'd Type E boxes which have generally better ratio's (taller and closer) than a std Type E box. The type 9 if from a 4 pot motor will have the same ratio's as the std. type E + the overdrive 5th. Whether they are stronger / weaker is debatable. both maybe ok behind a 200hp engine?
    Oct 2018
    South wales
    Thank you appreciate info
    Only want to do. It once lol
    9,200
    if itr has the long shaft it may be a diesel box with worse ratio. put it in 1st and count how many times it turns for one turn of output shaft.
