Results 1 to 6 of 6
Thread: Big very 8888
    Jan 2019
    Gerrards cross
    12
    Big very 8888
    Can eny one give me advice on my mr1escort front serspesion spent good money unfortunately still to high and very stiff rs struts Gaza insert concentric top mounts 1in lowerd rear,it is 1in lowerd rear with blocks in body shop at moment having Mexico front wings fited
    3,241
    Re: Big very 8888
    For what application? X-flow or Pinto (pinto weight is a bit porky) - all affect spring rate and static length. My std. springed RS has reasonably compliant suspension considering its cart / tractor heritage compared to modern stuff. Even the front dampers could be too stiff - that doesn't help!
    Jan 2019
    Gerrards cross
    12
    Re: Big very 8888
    X-flow 1700 the rear is perfect sits just fine front end had clamps on spring not by me I changed to rs 2000 struts not sure the spring are right got them Bertopower 1in lower not sure the lb would I need 2in lower to match the rear and 145ld springs
  5. #4
    Jan 2019
    Gerrards cross
    12
    Re: Big very 8888
    It will only be for road use and for shows thanks
  6. #5
    Re: Big very 8888
    It's always been a minefield with spring rates and ride heights on Escorts unless you have adjustable platforms. Various suppliers and spring manufacturers all seem to be different in one form or another. . The easiest way's to do it the old fashioned way, take the pring off and go to a shop and compare different lenghts. It's no good using Mail order for that reason.
  7. The Following 2 Users Say Thank You to Forest_rallying For This Useful Post:
  8. #6
    Jan 2019
    Gerrards cross
    12
    Re: Big very 8888
    Can eny one help looking to put 15in wheels on my mrk 1 Escort wat do you all think ? I have vented docs with m16 callipers rear arches have bin rolled car in body shop at mo
