Results 1 to 6 of 6
Thread: 4 link axle brackets
    2,656
    267
    Can anyone see a problem cutting a pair of 4 link brackets in half to weld them to an atlas?
    This is because the axle casing I bought a while ago has them set at different centres to the 4 link boxes in my car, so they're in the wrong place...
    Ideally they would normally be put on from the ends of the tubes then the fully floating stubs axles put on after.
    Re: 4 link axle brackets
    If you buy new brackets thats exactly what you would have to do to fit them to an existing axle.
    I can't see a problem.
    2,656
    267
    Just the answer I was looking for. Thanks.
    Jun 2004
    Bristol
    1,494
    18
    Yes, done that before when 4 linking a std axle
  5. The Following User Says Thank You to GavinR For This Useful Post:
  6. #5
    2,656
    267
    Quote Originally Posted by GavinR View Post
    I should have thanked you at the time aswell.
    Rob
  7. #6
    Mechanic dodgydoughnut's Avatar
    Dec 2005
    down south
    666
    just a little tip ive done afew times. don't cut them straight through the middle.cut them at an angle. Like 2pm to 8pm if that makes sense.
    [/SIGPIC]CHRIS
    WANTED MK1 2DOOR ESCORT COSSY OR XE MUST BE PERFECT AND FREEwell dont hurt to ask?
  8. The Following User Says Thank You to dodgydoughnut For This Useful Post:
