Results 1 to 2 of 2
Thread: s2000 water pipes
    ireland
    29
    s2000 water pipes
    hi guys, long time looker first time poster!! i am fitting a s2000 in a mk2 and its been run on jenvey throttle bodies, and am not running a heater rad, jus wondering what did you do with the 2 smaller water pipes on the top water outlet and the 4 smaller pipes on the water pump housing (i.e did you plug them up, join one to the other etc......) any help greatly appreciated!!
    Nov 2008
    north wales
    266
    Re: s2000 water pipes
    Just join one the top heater outlet to the bottom one and the other three on the water pump housing connect to other places on the engine.i.e one goes to the oil filter, one goes next to the top rad pipe outlet and i would blank the third off unless theres a place on the throttle bodies to connect to.hope that helps with your question.
