Rocket box tail housing
Hope you can help, the prop has let go and wiped the tail shaft off my rocket box... do any others fit.. type 3 etc?
ta
Skinny
Re: Rocket box tail housing
Only Type E fits. No others are even vaguely the same.
A replacement Type E tail housing should not be hard to source. The F2 stockcar guys most use a short (custom) tailhousing so the std one is not used.
