Results 1 to 14 of 14
Thread: Larger throttle bodies / intake manifods and boost
    Mar 2012
    Shropshire
    407
    Just another one of those idle thoughts and google isnt bringing up anything. What are the benefits of using a larger throttle body / intake manifold on a boosted application? and , if any, what would the signs be that you need one?
    Re: Larger throttle bodies / intake manifods and boost
    I always think of it like pouring a bucket of water down a pipe. If it doesn't go down the pipe quick enough you need a bigger pipe. I would imagine turning up the boost with lessoning affect on power would indicate a restriction. I would also imagine you need to look at the flow rates of all the pipework on the induction side as the restriction may not be the throttle etc.
    It may also be that bigger is not always better more boost more fuel and that would then need looking at ??
    experts feel free to add
    Mar 2012
    Shropshire
    407
    Sounds reasonable. I'm thinking a lot of people fit bigger throttle bodies etc long before the smaller ones have actually become a restriction too.
    25,110
    ive been there all that happens if you use too bigger body is the throttle becomes less progressive, one of my bmw turbo motors made 320bhp full throttle, half throttle it still had 270bhp i cant remember what quarter throttle was but its was still something like 200bhp
    Mar 2012
    Shropshire
    407
    I wont worry about the little stock sierra efi one on my setup then, not that I was anyway. I just have these odd thoughts sometimes.
    25,110
    Quote Originally Posted by theduck View Post
    with forced induction even only at 1 bar boost a throttle will support at least 100% more power than in an n/a application, your sierra body isn't going to get restrictive until at least 250bhp
    Mar 2012
    Shropshire
    407
    Maybe I should worry then
    On the low boost map which starts at 10psi and climbs to 18 psi it is making 275bhp and 240lbft, but we had some tyre slip so think it was realistically making more power up top than that.
    On the high boost map which was targeting 20psi as early as possible it made 285lbft at 3.5k rpm and then spun the tyres.
    25,110
    if you want to know how much the throttle is holding it back do two power runs one at full throttle and one slightly off full, if theres not much difference you dont need a bigger throttle.
    TBH, i think i think the plenum shape would be more of a issue than throttle body, i would suspect no1 cylinder would not get filled as well as the others.
    Mar 2012
    Shropshire
    407
    Glad I made the post now. Will definitely give that a go next time I have it on a dyno, and maybe a new intake setup will be on the cards in the future.
    Nov 2004
    Sweden
    1,167
    Good torque there!
    I use a 3" Volvo 850 GLT throttle body (similar power levels) but can't say if it is necessary or not. As you know I also have a YB style inlet manifold with a larger plenum. I am however thinking about a smaller volume plenum chamber to increase throttle response.
    Less resolution is a real risk with a bigger throttle body, ideally I'd prefer a progressive linkage/quadrant.
    Gustaf
    Nov 2010
    Australia
    170
    12
    Gustav will that Volvo throttle body adapt to a Sierra Pinto inlet manifold easily? Thanks
    Nov 2004
    Sweden
    1,167
    Not really, I have only used it on custom manifolds.
    My first injection engine used a Sierra EFI inlet with a slightly larger Saab TB, I used an adapter plate then. I guess you can do the same with the Volvo TB and enlarge the inlet hole, but "easily"...nah...
    Gustaf
    Nov 2010
    Australia
    170
    12
    Thank you. Last time my car was on the dyno we checked pressure difference between the turbo outlet and inlet manifold. At 20psi boost pressure there was only 1psi difference so I doubt the Sierra throttle body is causing any significant restriction. You did only tell me that a couple of weeks ago haha. Cheers
  14. The Following User Says Thank You to OZMK1 For This Useful Post:
  15. #14
    Mar 2012
    Shropshire
    407
    Good to hear from someone else running the sierra manifold and tb. Out if interest what power and torque are you making on 20psi?
