Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 41 to 80 of 130
Thread: MK1 Escort ST170
  1. #41
    Jul 2006
    bristol
    10,882
    892
    Re: MK1 Escort ST170
    Quote Originally Posted by eric View Post
    I have to give Piper a call next week find out more on their cams and if you can re-shim the followers
    Ive been told you can swap the followers around to fit as needed then just buy the ones you need to
  2. #42
    Holland
    32
    252
    32
    sorry to dig up an old thread, what sort of ECU are you using with the VVT?
    I was looking for one these engines in a rwd car.
    Could you give a rough price ideas on TBs,Flywheel and stuff
    would silvertop zetec flywheel fit these engines?
  3. #43
    I an using the omex 600 which can control the vvt, you can set a tps value and rpm to switch the vvt on or off thats all, most after market ecu's are basic when it comes to control the vvt.
    Try http://www.retroford.co.uk/ this will give a good idea to the costs envolved and search Turbosport loads of good advice and info.
    I used the 1.8 zetec flywheel drilled to except a pinto clutch then changed to a TTV Racing flywheel using the same clutch setup.
  4. #44
    Started on the escort again, sorted out the oil cooler bracket just needs painting to finish, just fits upright with a few mm to spare.
    Brought a Rally Design tension kit to replace the twin cam anti roll bar looks good now that it's fitted but was not a straight forward fit, the chassis body brackets required work to finish off and some wrong bolts came with the kit but then it is cheaper than most.
  5. #45
    May 2007
    Up North
    1,352
    79
  6. #46
    Feb 2010
    Kent
    222
    nice work thought you had lost interest.good to see your back on
  7. #47
    Quote Originally Posted by Nuttynil View Post
    Never lost interest in the old girl it's been a tad cold which slowed things down a bit, I did come close to giving up for a while when I warmed up a spray can in the kettle which I forgot about, I carefully lifted the tin only to slip through my fingers, on hitting the floor it promptly exploded I was covered in blue paint I was lucky as the blast of paint went away from the escort and my sons sierra cosworth some days you just got to laugh
  8. #48
    The grp4 struts have arrived it's the last thing i going to buy this year, well that's what I told the wife
    They are top quality with good welding and finish made with genuine bilstein stubs looking forward to using the escort again.
  9. #49
    Not been happy with power of the st170 engine with the vvt it is very flat after 4000 rpm, tried various settings on the vvt nothing seemed to make any differance to the power
    anyone else had this problem with the st engine, the vvt does seem to be a bit hit and miss.
    Decided to bin the vvt and use the vvt delete Cat Cam’s 2301013 profiles proved to work well with the std internals on the dyno these cams have made 207 bhp / 177 lb.ft of torque
    Still waiting for the cams to be delivered but was bored so made a start on the st
    Checked the valve clearances and bucket sizes all within ford spec.the advice from catcams if
    the head has not been messed with the valve clearances should be ok with the new cams,fingers crossed at 16.00 for each bucket if not
    Tapped the oil feed and blocked off with a 6mm grub screw 18mm core plugs yet to fitted to block off the vvt solenoid hole.
    Made a steel plate bolted to the head for the dial gauge magnet to stand on
    Just need some cams now
  10. #50
    Feb 2010
    Kent
    222
    Nice worK really interesting read those struts look the bees knees what springs are you using .Neil
  11. #51
    250lb 12inch springs
  12. #52
    Feb 2009
    essex
    1,986
    looking good
  13. #53
    Jul 2006
    bristol
    10,882
    892
    Nice mate can't wait to hear the diffrece the cat cams make.
  14. #54
    Quote Originally Posted by trig View Post
    Me to Trig, at the moment it's slower than my old blacktop.
  15. #55
    Dec 2008
    scotland
    298
    hi mate the vvt needs to be operated with a pwm output as its continously variable, NOT off and on as you had been using it. its works well when controlled like this but you would need a dtas60/s80 or omex 710 or the like and it mapped to suit... i dont blame you for the way you have went and it will be good when you get the cams in.be interesting to see the difference.
    track fiesta on all the right bits.....
  16. #56
    Quote Originally Posted by dug112y View Post
    Totally agree that using the vvt by just switching is a poor substitute for good power but there has been some good results using this method just did not work for me
    The info from catcams web site (Dyno proven to produce 207 bhp / 177 lb.ft of torque)
  17. #57
    Jan 2011
    croydon
    35
    nice project, il be watching this thread as im getting near ordering them cat cams, just a quick question were's the core plug got to go to block the vvt, is it the hole next to the one you have tapped and fitted a grub screw
    cheers nik
  18. #58
    Quote Originally Posted by nik_plant View Post
    cheers nik
    Yep just above where the grub screw is.
  19. #59
    Jan 2011
    croydon
    35
    might be a stupid question so I apologise in advance, but why are you blocking the oil feed and vvt hole ? Only reason I ask is a asked cat cams what I need to do to the head and they said just bolt the new cams in, check valve tolerance and away you go
  20. #60
    If you leave the soleniod in you don't need to block the oil way off but if removed these will need to be capped to stop the flow of oil, left uncapped you would fill the valley where the plugs are.
  21. #61
    Jan 2011
    croydon
    35
    yea i see now i should have looked at my engine before asking the question, cheers
  22. #62
    The catcams are in and timed up, the inlet camshaft seal was a pain to install as the inner lip would not seat properly, I found a easy way is to install the seals with the top cover removed line them up refit the upper cover, worked a treat with no leaks
    1st start did not go to well was hard to fire up and keep running spitting back with some back firing and exhaust manifold temp to high, recheaked the timing which was all ok tried again still the same after changing the fuel map tried again now sorted runs well nice sharp throttle response the intake sound is even louder, track days may be a problem, not had the chance to go for a drive yet as it's raining again.
  23. #63
    Oct 2008
    Sunderland
    155
    Nice work Look forward to hearing what sort of difference the cams have made
  24. #64
    Jan 2011
    croydon
    35
    nice looking forward to hearing some feedback on the cams, when youve had a drive
  25. #65
    Just had the 1st drive with the catcams installed very very impressed with these cams the st engine has come alive at last good torque from mid range pulls hard at under 4000rpm and the induction sound has changed for the better, with the vvt on full power the induction sound was odd from mid range, glad to say that has all gone, so next up is the final mapping
  26. #66
    9,219
    168
  27. #67
    Mechanic bennods's Avatar
    May 2009
    Staffordshire
    731
    23
    Loving the motor mate. Considering a st170 for my next project. How did you get on with the tension struts? Do they make much difference? Thinking of using them myself.
  28. #68
    Spanner Monkey mk2mania's Avatar
    Feb 2010
    lancashire
    352
    hi eric, iam in the throws of building an ST motor for my owd pig, we are using a rick wood cnc head n cams , with the usuals, (jenveys, dta 600 ,tony law exhaust manifold, arp bottom end bolts etc ), i just wondered if you were using or had heard of anyone using different oil pumps or having problems with the standard ones, thanks rick
  29. #69
    Quote Originally Posted by mk2mania View Post
    I have heard of the std oil pump failing on the zetec engines when revved over 7000rpm but this is info from the internet , there are uprated pumps available but I have never used or know of anyone using one yet, I used the later black top engine for over 2 years which was pushed often upto the 7300 rev limit with no problems. the st is set to the same. What rev limit will you be using?
  30. #70
    Quote Originally Posted by bennods View Post
    The tension kit is working well it is a bit over kill for road use but you can set up the correct caster which made a big difference to my mk1
  31. #71
    Feb 2010
    lancashire
    352
    iam not sure what limit to put on it, ive used competition bearings from the states and arp'd the bottom end and fly wheel,, so hoping to get it screaming (but safeish) what are your thoughts on a soft and hard cut limit with the dta 600
  32. #72
    Not had the pleasure of the dta 600, I have my omex 600 set to ignition cut at 7300 & fuel cut at 7500rpm just under when the oil pump goes tits up
  33. #73
    Apr 2009
    kent
    20
    Hi eric have you had it on the RR yet ?
    Gerry
  34. #74
    Quote Originally Posted by v6gerry View Post
    Gerry
    Not yet Gerry the mapping is not being done on the rollers but by a friend who normally maps evo's, a power run will follow some time after
  35. #75
    Apr 2009
    kent
    20
    I'll drop in and see you at some point , keep up the good work with all this sun you should be out enjoying it !!
  36. #76
    Little update
    Fitted a Mocal Oil tank plumbed it into the cam cover and std zetec block breather seems to work really well
    A nice set of alloys from Rally Design with Yoko A048s
    should have used a set of decent tyres long ago the grip is amazing
    Bonus pic
  37. #77
    Feb 2010
    lancashire
    352
    hi eric, ive finally got my mate ste (sc auto electrics) to wire the dta s60 in , the tony law manifold is a work of art and just fits in,, weve put it on individual coils and 45 jenvys,, i endded up modifyin, water rail alternator bracket, sump, all sorts , but its in and running now,, found a map online for a ford ka with a 170 in on bodies with cat cams,, seams to run ok for now till i get it on a dyno and let someone with a bit more savvy have a play,, ( your mk1 looks well )
  38. #78
    Sounds good have had a chance to see how the power of the st compares on the road to your old engine yet.
  39. #79
    Feb 2010
    lancashire
    352
    no not yet,, ive got to pull the exhaust manifold of 1st and rewrap it with some more heat wrap, it keeps gettin the wirin and pipework to hot,, till i sort that i cant run it to long,, it better be more power n torque and be a lot smother,, the old 1 went well but was on carbs and a basic webber alpha with a crap ignition timming map,, i will let you know how i go on,,,, cheers rick, ive still got to sort the suspension and the inside out yet, iam goin to get an MSA book on it, and hopefully do a couple of local events
  40. #80
    Final edited photo, looks much better with out the traffic light in the background
