Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 81 to 120 of 130
Thread: MK1 Escort ST170
  1. #81
    Mar 2008
    manchester
    724
    Re: MK1 Escort ST170
    just been having a read, as i have followed a similar route, although i have had to retain the standard air/fuel induction. at the moment, i am running the vvt with the shift light, but am in the process of getting it done corectly. have to say with the vvt off the engine is totally flat, but with it wired in, coming in at around 2.7k, it comes alive! approx 95bhp@3k, 169bhp@5k upto 6.7k ish. without it, i drop right down to 125ish bhp. took a while to realise why things werent working, but soon realised it was the way is wired it! i assumed the shift light was giving me a positive switch, turned out to be a neg switch! have put the vernier on ex cam, hoping to get 190 ish with it working right. funny how some have success and others dont. if i could put a set of t/b's on it, well, id be well away!
  2. #82
    Mar 2008
    manchester
    724
    btw, top job on the engine bay renovation! very smart!
  3. The Following User Says Thank You to dyn-car-gwyn For This Useful Post:
  4. #83
    Quote Originally Posted by dyn-car-gwyn View Post
    Cheers mate and well done for making the vvt work
  5. The Following User Says Thank You to eric For This Useful Post:
  6. #84
    Spanner Monkey mk2mania's Avatar
    Feb 2010
    lancashire
    352
    finally got it in and running,, with new suspension and interior,, also nearly ready for log bookin,, ignore all the wax oil
  7. #85
    Well done, not long before you can give it a damned good thrashing do you have anymore pics of the Tony Law manifold
  8. #86
    Feb 2010
    lancashire
    352
    i call it built for use and abuse
  9. #87
    Had the MK1 on the rollers today at CPL Racing Fast Ford were there and will be doing a feature soon.
    The results from the power runs were not quite as expected 167bhp with 171lb of torque, the low bhp figure was a surprise as the torque figure was high for the st engine I can only think there is a cam timing problem, possibly to much advance.
    Next step is a visit to the rolling road to have the map sorted, still running at a safe 27 degrees ignition advance so there is more power to come fingers crossed.
  10. #88
    Just had my ST170 head flowed by Andrew at A L Developments should be all built back up at the weekend, hopefully should give the power increase I am after, fingers crossed.
    Spec so far,
    VVT delete catcams and verniers
    Flowed Head
    45 Jenveys with flowed inlet
    Omex 600
    Custom 4 2 1 Exhaust by Zero
    This is far as I will take the ST engine if the power is not there engine number 3 next year?
    The pictures don't do justice to Andrews work on the ports
  11. #89
    Jul 2006
    bristol
    10,882
    892
    Looking good bud not seen this one for a while
  12. #90
    Aug 2006
    Christchurch, New Zealand
    463
    Quote Originally Posted by eric View Post
    Looking very good.
    I hope it doesn't come to that and you can get the power that you wanted, but what engine will you go for if it doesn't?
  13. #91
    Quote Originally Posted by trig View Post
    Still working on and off on the escort, built a new Tran-x diff using 45/90 ramp angles as recommended by Tran-x for track use, just had the head sorted just some new brakes to sort out.
  14. #92
    Formerly harrier mk2 Decade Plus User Fridgeman's Avatar
    Jun 2007
    Derby, United Kingdom
    2,529
    151
    not read all the thread but a guy down at our sprint club has a very nice sorted one ,goes like fook and sounds close to a BDA of full chat.
    EVERY DAY,S A LEARNING DAY
  15. #93
    Quote Originally Posted by Pikey15 View Post
    Looking very good.
    Possibly a Duratec makes good power with good reliability
  16. #94
    Apr 2009
    kent
    20
    all looking nice eric , maybe you need to get it mapped up on a RR to get the best from it ! are you going to ford fair next month ?
    Gerry
  17. #95
    Quote Originally Posted by v6gerry View Post
    Gerry
    As this is the last of the engine mods it will now be mapped properly hopefully over 200bhp now.
    Not a ford Fair this year can't get the time off.
  18. #96
    Jul 2006
    bristol
    10,882
    892
    If you are thinking of duratec bud I take you out in mine at some point
    maybe you should put your name down for my track day
  19. #97
    I will like to take you up on that if I do go to a duratec engine, seen your latest post on your progress with your MK1 coming on really well keep it up Trig, it's quite a drive to your neck of the woods if only it was a bit closer
  20. #98
    Jul 2006
    bristol
    10,882
    892
    Where a bouts are you then buddy?
  21. #99
    Near Sandwich Kent
  22. #100
    It's all back up and running, 20 minutes of panic as it would only run on cylinders 2 and 3 a faulty coil pack was to blame, strange that the coil pack failed as it was working fine with no miss-firing before the head was removed
    Next step brakes and a properly mapped not sure who to use yet.
  23. #101
    boXXer
    Guest
    Saw this yesterday @ lydden. Beautiful car and makes me want another one.
  24. #102
    I support TS Turbosport Subscriber
    Nov 2008
    In a shed in Coventry
    1,378
    151
    Nice bay that and top car
    1 question if you dont mind me asking ,what alternator have you used ?
  25. #103
    Quote Originally Posted by Steve L View Post
    It from a Sierra http://www.ebay.co.uk/itm/ALTERNATOR...item1c288c6847
  26. The Following User Says Thank You to eric For This Useful Post:
  27. #104
    Nov 2008
    1,378
    151
    Thanks for that ,Been searching all day on here
    P.s what bracket have you used?
  28. #105
    No problem, need to check the alternator is definitely the right one as there are some slight variations i am 99% sure it is the one I use. The mounts are from http://www.raceline.co.uk/products/p...8&CategoryID=2 the bottom mount is rubber mounted so the alternator doesn't get shaken to bits, the top adjuster is not that tough as it broke in two last time out at Lydden.
  29. #106
    Nov 2008
    1,378
    151
    Oops ,Might be best if i use 6mm steel if they snap like that
    Cheers for the info
  30. #107
    Cheers for the info
    This is being replaced with a much improved version, should be with me soon
  31. The Following User Says Thank You to eric For This Useful Post:
  32. #108
    Spanner Monkey Unclebuck's Avatar
    Nov 2009
    314
    Did you ever get this on the RR, I'm interested to see what power you achieved?
  33. #109
    Quote Originally Posted by Unclebuck View Post
    Not yet still running my map one of the reasons is the exhaust may be changed so no point until I decide what to do, the same spec engine using the same catcams made 207bhp and 174 torque
    Video at Lydden with my mates mk2 not a bad pace for a old zetec http://www.youtube.com/watch?v=995XQfwuEo4
  34. The Following User Says Thank You to eric For This Useful Post:
  35. #110
    Dec 2008
    scotland
    298
    240 odd bhp i reckon this will do....
    track fiesta on all the right bits.....
  36. #111
    Jun 2003
    Teesside
    2,406
    Do the cams go straight in or do they need re-shimming
  37. #112
    Quote Originally Posted by robrs2 View Post
    Catcams are very close to Fords tolerance, I did not have to change any of the buckets when I installed mine as they were all just within spec.
  38. The Following User Says Thank You to eric For This Useful Post:
  39. #113
    Dec 2013
    Portugal
    26
    I do not know what to say, spectacular, but many many congratulation.
  40. #114
    3,641
    How are you controlling the VVT at the moment?
  41. #115
    I removed the vvt and installed catcams and verniers just could not make the vvt work, had a choice to either upgrade the omex 600 or go with new cams expensive option but they bring this engine to life.
  42. #116
    Dec 2013
    kent
    82
    You should have put a pintosaurus in it eric then you would have been a bit closer to that rs2000 lol !
    I am building the engine closer to 2.0 litres so you can catch up
  43. #117
    Quote Originally Posted by goldy View Post
    Sod off you old git, the poxy old boat anchor will probably expire again
  44. #118
    Apr 2013
    Falkirk
    125
    Looks good bud
  45. #119
    Jul 2006
    bristol
    10,882
    892
    Hopefully catch up with you this year bud
    Dont forget my track days at combe
  46. #120
    Hope so Trig, try to get to Lydden or Brands I buy you to a bacon sarnie and probably a cuppa if your lucky
  47. The Following User Says Thank You to eric For This Useful Post:
