Results 1 to 9 of 9
Thread: Twin 45’s balance
    May 2018
    Stoke on trent
    66
    Twin 45’s balance
    This must be a common question, however I am looking for a solution.
    How do you use a Syncrometer on a Pinto running twin 45’s and long trumpets in a mk1 Escort, the inner wing prevents access. I have the long rubber 90* adaptor but this does not help. Is there an easy solution to balancing these. Any help/ ideas on how to resolve this appreciated.
    Mark
    3,241
    Re: Twin 45’s balance
    For balancing purposes, whether the ram pipes are there or not isn't critical. Alternate method is add some barbed spigots in the inlet runners and use m/cycle vacuum gauges - a rack of 4 makes balancing a doddle.
    i use a length of heater hose and my ear, plenty good enough
  5. #4
    Mechanic davemk1's Avatar
    Jul 2011
    herts
    502
    My thoughts exactly
  6. #5
    May 2018
    Stoke on trent
    66
    Thanks for the replies
  7. #6
    I used the same. Pretty easy to do and you do notice the engine running improves so you know you are going the right way.
  8. #7
    Sep 2005
    California USA
    284
    58
    Fit short trumpets that allow installing the meter. If that’s not an option.... remove trumpets
  9. #8
    2,659
    268
    Daft question really, but I presume when doing this all you're trying to do is match the vacuum between cylinder runners? I've got a set a vacuum gauges somewhere.
  10. #9
    yes
  11. The Following User Says Thank You to Graham For This Useful Post:
