Need a 1600 Cross flow Sump for escort mk1 or MK2
Mine is beyond repair hence would apprciate a useable sump for the above application .
An help is appreciated
Kind Regards
Raffi
Re: Need a 1600 Cross flow Sump for escort mk1 or MK2
You may struggle to source the 1600 sump. You can convert (hammer) a 1300 sump into shape!
Yes i am Aware . The issue is the depth and the sideclearance for the rods to clear .. . This is for a Rally car and when i pruchased the car it was without proterction and is now beyond repair . I might have to cut floor of the bowl from the 1300 and weld it in palce of the damaged one .
Thanks anyway
Just t o add to the request i am after a rear bowl sump not after a big wing sump
Hi mate I know the guy who will repair it :-)
