Results 1 to 5 of 5
Thread: 1.6 Pinto
    Mar 2015
    Stoke on Trent
    23
    1.6 Pinto
    Hi All,
    After a 1.6 pinto block or full engine, one with a Oct 76 cast date would be great!
    Thanks,
    Paul
    Apr 2011
    north wales
    260
    Re: 1.6 Pinto
    I have a 1600 GT Pinto engine, it is complete, but I don't want the block or sump, I just want the head, dizzy, flywheel etc-etc, so if you just want a block, with crank, rods, pistons, not sure where the cast date is, this is a true 1600 short stroke engine, not a later long stroke small bore 1600.
    Where do I find the cast date !!??.
    Cheers. Al.
    Sep 2013
    Matlock
    252
    36
    Re: 1.6 Pinto
    I have a Capri 1600 block, bored to 1700 using 90mm forged JE pistons,Cosworth YB steel conrods and polished standard crank with new bearings. All new just loosely assembled for trial fitting. From a shelved hillclimb/sprint project. Some ancilliaries also available.
    Apr 2011
    north wales
    260
    Re: 1.6 Pinto
    The 2 Pinto 1600 I have here have the numbers -:
    S Y 18239
    S O 12338
    What eve that makes out to be.
    Jan 2013
    Kingston,Jamaica
    33
    317
    Re: 1.6 Pinto
    Cheers....got a 1.6 pinto for sale if still needed
