Results 1 to 11 of 11
Thread: Cosworth N/A for sale.
    Jun 2015
    Herts
    227
    Recently built Cosworth YB N/A with the following parts fitted.
    Re-bored and honed never been run 205 block 93mm.
    Block Pressure tested and chemically cleaned, New core plugs
    Wossner N/A pistons (New)
    H Beam rods (New)
    Injection crank. Polished. Std mains and ends
    ARP Bolts
    HD bearings (New)
    HP Oil pump (New)
    New water pump.
    New stat housing.
    Distributor blanked-off
    Coil pack including mount (New)
    36-1 Trigger Wheel
    Crank Sensor (New)
    High Output Alternator (New)
    Burton HT Leads (New)
    ENA Hydraulic Followers (New)
    Ported and polished 2WD head (Measures 137.8)
    New Std sized inlet and Exhauts valves.
    Newman double valve springs (New)
    Newman N/A PH2/3 Cams (New)
    Billet cam caps (New)
    ARP head bolts. (New)
    Kevlar HD Timing belt (New)
    New Belt Tensioner
    Vernier Cam Pulleys (New)
    RS2000 Alloy sump (New)
    All new sensors Temp, oil etc.
    Burton Alloy Inlet manifold (New)
    Wiring loom with terminals
    Lightened Flywheel.
    Victor Reinz gaskets.
    Probably forgot loads of stuff but you get the general Idea.
    Basically add an ECU, Throttle bodies and exhaust manifold and its ready to go.
    The Engine is assembled but the head is not pulled down so can be removed for inspection.
    Due to a change of plans Im thinking of selling as it is, I dread to think how much it cost.
    Looking for 5.5k but open to sensible offers.
    [img]http://media2.turbosport.co.uk/2013/11/20190321234876821820180815_153527.jpg[/img
    World Champion Decade Plus User meXEco's Avatar
    Mar 2003
    TRURO
    6,012
    240
    Re: Cosworth N/A for sale.
    Jun 2015
    Herts
    227
    More photos available on request.
    Can be viewed Herefordshire.
    Spanner Monkey Mkdu's Avatar
    Oct 2009
    337
    Hi,
    The crank is not a cosworth one if I understand well.
    What are the spec of cam's ?
    Coil pack mounting stuff looks clever !
    I'm thinking of replace my cossy by a better one, with solid lifter, steel crank...
    Your engine could be a good start...
    Oct 2009
    337
    Ok I found for cam's from newman catalog PH2/3 fast road 2500-7000 288/288
    Jun 2015
    Herts
    227
    Yep thats it 10.41 lift inlet and exhaust.
    Chosen because Hydraulic lifters can be used.
    Dec 2011
    isle o sheppey
    12
    Very nice that im just having one done by harris and there not gonna use the cozzy crank either,,instead there gonna use a pinto one
    Jun 2015
    Herts
    227
    Yep, I was informed the same, Pinto crank is plenty strong enough. Its rods that are the weak point.
    Good luck with it, you cant beat the induction roar of a YB N/A.
    23,402
    231
    ive used pinto cranks in turbo ybs
    Apr 2019
    Kent
    Is this still available
    Bodger Frits's Avatar
    Aug 2016
    Netherlands
    81
    Do you sell parts separately? Or only complete engine?
