Cosworth N/A for sale.
Recently built Cosworth YB N/A with the following parts fitted.
Re-bored and honed never been run 205 block 93mm.
Block Pressure tested and chemically cleaned, New core plugs
Wossner N/A pistons (New)
H Beam rods (New)
Injection crank. Polished. Std mains and ends
ARP Bolts
HD bearings (New)
HP Oil pump (New)
New water pump.
New stat housing.
Distributor blanked-off
Coil pack including mount (New)
36-1 Trigger Wheel
Crank Sensor (New)
High Output Alternator (New)
Burton HT Leads (New)
ENA Hydraulic Followers (New)
Ported and polished 2WD head (Measures 137.8)
New Std sized inlet and Exhauts valves.
Newman double valve springs (New)
Newman N/A PH2/3 Cams (New)
Billet cam caps (New)
ARP head bolts. (New)
Kevlar HD Timing belt (New)
New Belt Tensioner
Vernier Cam Pulleys (New)
RS2000 Alloy sump (New)
All new sensors Temp, oil etc.
Burton Alloy Inlet manifold (New)
Wiring loom with terminals
Lightened Flywheel.
Victor Reinz gaskets.
Probably forgot loads of stuff but you get the general Idea.
Basically add an ECU, Throttle bodies and exhaust manifold and its ready to go.
The Engine is assembled but the head is not pulled down so can be removed for inspection.
Due to a change of plans Im thinking of selling as it is, I dread to think how much it cost.
Looking for 5.5k but open to sensible offers.
[img]http://media2.turbosport.co.uk/2013/11/20190321234876821820180815_153527.jpg[/img
Re: Cosworth N/A for sale.
More photos available on request.
Can be viewed Herefordshire.
The crank is not a cosworth one if I understand well.
What are the spec of cam's ?
Coil pack mounting stuff looks clever !
I'm thinking of replace my cossy by a better one, with solid lifter, steel crank...
Your engine could be a good start...
Ok I found for cam's from newman catalog PH2/3 fast road 2500-7000 288/288
Yep thats it 10.41 lift inlet and exhaust.
Chosen because Hydraulic lifters can be used.
Very nice that im just having one done by harris and there not gonna use the cozzy crank either,,instead there gonna use a pinto one
Yep, I was informed the same, Pinto crank is plenty strong enough. Its rods that are the weak point.
Good luck with it, you cant beat the induction roar of a YB N/A.
ive used pinto cranks in turbo ybs
Do you sell parts separately? Or only complete engine?
