Results 1 to 5 of 5
Thread: Cosworth YB lean on lambda gauge ?
    Oct 2015
    Essex
    347
    33
    Any reason why blipping the throttle on idle leans out the mixture making engine almost stall when dead cold ?
    Fuel pressure correct 3 bar and increases as vacuum decreases
    Ignition is fine and drives fine when warm
    Hav also changed water air sensors
    Next on list is Throttle sensor issue I guess ?
    Any help be appreciated
    Oct 2015
    Essex
    347
    33
    Dont worry sorted it :-)
    Re: Cosworth YB lean on lambda gauge ?
    how ? Just nosey.
    Oct 2015
    Essex
    347
    33
    Dodgy connection on plug TPS
    👍 nice fix
