cosworth fuel set up
can any tell me if this set up is wright ,its for my cosworth engine in my mk1 escort , am coming from the tank ,fuel cradle filter, pump then am not sure. is it non return valve then fuel regulator the return to tank ,or is it the other way round,as in fuel rail first then fuel regulator and non return valve any help would be welcome cheers mick
Re: cosworth fuel set up
you dont need a non return valve, but if you have one its usually in the end of the pump.
the fuel from the pump goes to the rail, then regulator then returns back to tank
