Hi guys
A little bit of advice please if you would be so kind ..
so this is how my issue started ...
TVR 1600m 1976
mild state of tune .. fast road
running a non vacuum 45d4 distributor side exit cap ( original screw on .. screws removed adapted to clip on )luminition in cap electronic ign ( points replacement type )
twin 40s maybe running a tad rich .. kicks out smoke black/grey
was as starting a running fine ... no choke on cold start , bit stand off when cold ..
just started every now and again in the garage not driven
done this for a while now , decided I was going to change the RVI 2430 rev counter that has never worked.. replaced it with a dolomite smiths one.. RVI use a strange link wire which I joined together.. car wouldn’t run without doing this .. anyway new wire ran from the - side of the coil and the dolomite rev counter sprang into life
I’d ran out of time to finish the job , so went back to the weekend after..
car started .. but wouldn’t rev ... felt like it was on 2 cylinders.. the engine died and wouldn’t re start .. fuel gauge was close to empty so I put it down to no fuel .
£15 lighter with two cans of petrol .. ( I remember the days when you could just squeeze £2 into a fuel can ) poped it in .. still wouldn’t start .. turning over but no spark
12 volts ar the coil .. no spark out of the coil or plugs ..
have i killed the coil / ignition kit I thought by replacing the rev counter ... I couldn’t understand it
anyway I’ve bought a accuspark stealth ign kit with 12v coil ...
fitted it .. but still engine won’t fire..
checked again for 12v and it’s there ... I put 12v from the battery to the coil and by touching it feed on and off I get a spark inside the cap .. and then at one of the plugs ..
plugs are wet .. blow torched them dry .. no difference.. will not spark when engine is cranked
sorry guys long winded but thought I’d give as much if as I can ..
thanks in advance
chris
