I'm rebuilding a 205 injection engine to use in my RS2000 with twin 40s, ported but std valve head, and RL30 cam. Its from an 89 sierra. I've measured the pistons and they're around 1.1 mm down from face of the block. All info i read is that they are normally 0.5 mm down. I'm sure its not a low CR engine. I want to get to around 10.5:1 CR and will measure the head volume to work it out, but i had hoped to take about 1.5 mm off the head. i need some advice. Has anyone seen pistons 1.1 mm down? i don't really want to have to get the block machined....
