RS2000 Dash Pod Clock
Bit of help please.
I need to take the clock apart. I've got the clock out of the pod but I can't get the black trim ring off the front, how does it come off? I assume once its off the clock comes apart by prising the front off the main body as I guessing its a crimp fit.
Re: RS2000 Dash Pod Clock
Most instruments you need to carefully uncrimp the black trim ring, working from the back go slowly round in a circle with a tiny screwdriver or similar tool to lever the crimp straighter
