Results 1 to 3 of 3
Thread: hub question
    Spanner Monkey Mkdu's Avatar
    Oct 2009
    417
    14
    hub question
    Hi all,
    I've been told that hubs (black on pics) are not good to use with genuine 4 spoke RS2000 alloys.
    Because it don't have the square end like the other one.
    The wheel is not centered, and at some point the stud will broke.
    What do you think ?
    Click image for larger version Name:	IMG_0794.JPG Views:	51 Size:	28.8 KB ID:	83853Click image for larger version Name:	IMG_0793.JPG Views:	52 Size:	23.5 KB ID:	83854Click image for larger version Name:	IMG_0792.JPG Views:	52 Size:	27.4 KB ID:	83855Click image for larger version Name:	IMG_0791.JPG Views:	52 Size:	29.6 KB ID:	83856
    3,241
    Re: hub question
    If they are genuine RS alloys you will be using tube nuts that are - in my case at least - a fairly snug fit through the wheel - I have to use 10mm spacers on the back due to disc conversion so the 'spigot' on the hub virtually doesn't exist!
    Oct 2009
    417
    14
    Re: hub question
    Those are Group 1 fitment with inserts in RS alloys.
    'Tube nuts' are I think, better, more like group4 setup.
