Results 1 to 6 of 6
Thread: cossy sump breather- to where?
    Jun 2014
    plymouth
    150
    I have now fitted my yb engine and was wondering what I should connect the metal breather to (located on left hand side of engine)
    I guess it would have originally gone to the airbox, BUT as I wont have an airbox where should I connect it to?
    I will have just a cone style air filter then into turbo,
    Am open to suggestions thanks
    colin
    3,239
    Re: cossy sump breather- to where?
    I suspect you have a oil catch can? That's where I'd run it to - especially with a turbo which will suffer with increased crankcase compression so case breathing is vital to avoid oil leaks.
    Jun 2014
    plymouth
    150
    Hi
    I don't have a catch tank at moment no, what woud a standard cosy use? straight to airbox then?
    3,239
    Yep.
    Mar 2008
    west bromwich
    1,861
    You really need a oil catch tank on a cossy the oringnal system not that good , as said help to relives the crank case pressure
    Jun 2014
    plymouth
    150
    thanks chaps, will do
