Results 1 to 10 of 10
Thread: Please help non start essex v6
    Jul 2002
    southampton
    379
    Help please non start Essex v6
    weak to no spark car don’t even fart when use a squirt of the good stuff into carb
    Coil resistance across positive and king lead terminals, and earth / king terminal seems ok
    Have tried another coil and king lead
    Ignition on I get 12v on earth and live terminals on coil ( I think that’s normal as switches on cranking yes?
    I have tried putting a new live to coil + terminal from battery
    I have tried a jump lead to earth engine and chassis
    I have loosened dizzy bolt and rotated dizzy back and forth a tad to see if it’s earth is iffy
    I have tried another electronic ignition unit in dizzy
    I remove earth from coil place king lead by a turret bolt and touch a earth wire from battery to coil negative no spark!!
    This is on 3 different coils! (Yes ignition was on)
    I don’t know what to do next apart from find a old school mechanic
    Any advice ?
    I’m really at my wits end
    southampton
    Mechanic davemk1's Avatar
    Jul 2011
    herts
    502
    Re: Please help non start essex v6
    Stab in the dark here I'm afraid but could it be anything to do with the points?
    not sure what to advise, but without a condensor connected to the circuit you wont get a spark by simply earthing the coil!
    Jul 2002
    southampton
    379
    Electric ignition
    and I was under the impression if you live a coil and strike a earth toother side you will get a soark
    from
    king lead
    southampton
    Quote Originally Posted by apples24 View Post
    Electric ignition
    from
    king lead
    you might if you lucky, but as i said you need a condenser in the circuit
    3,239
    Graham - as he said, its electronic so no points / condenser.
    Unless you are working with a known good Ignition ecu ie. it comes off a working running engine its a good chance its goosed.
    Jul 2002
    southampton
    379
    Already replaced it to check
    southampton
    my point was you cant check a coil by simply earthing it!
    Jul 2002
    southampton
    379
    I thought you could, I know you put multi meter across it
    That’s google for you I was to remove earth and give it a earth striking it across to watch king lead spark
    southampton
    if your lucky you will get a spark, but thats by no means certain!
