The bearings in my half shafts appear to be 2mm deeper than the grooves in my atlas, so the drive shaft flange doesnt quite sit flush with the axle flange, is this normal?
Sent from my SM-A520F using Tapatalk
You should have a spacer to make up for the drum backplate 👍
If using bolt on brackets for callipers I think they do the job.
Ahhhh that makes sense, ta mate
has the axle stub been cut and rewelded back on
As per wildo Ford allowed the back plate to fill that gap.
Please don't be tempted to just tighten in the 4 bolts 😋
Small spacer will solve it!
Sent from my CLT-L09 using Tapatalk
i think so yes, i believe it was shortened to baby atlas width
thanks for the replies
Thanks for the head up, i have no diff at all yet but will make sure the shaft dont bottom out
