Looking for some advice on fixing a rear axle movement issue on my Mk2, when turning in there is an odd feel to the rear end, almost like the axle is moving when the car starts to roll, i have panhard rod fitted and im aware that adjusting the rod angle from the adjustable chassis bracket will alter the rear roll centre which is currently quite low......my question is - will the postion / angle of the rod cause this rear end loose feel by causing lateral movement to the axe if the angle of the rod causes it to b furthr into its pivot arc thu casin more lateral movement frm the vertical??
