Results 1 to 2 of 2
Thread: 4 Link Bracket Help
    Jan 2015
    Wales
    4 Link Bracket Help
    Hi guys,
    Tried a bit of research on this but want to confirm a few things. Bought a shell with Clubman spec boxes welded in, bought some clubman spec arms and brackets. I need to weld the bracket to the axle now, so far my axle is still sitting on the standard springs on the shell. Is it best to weld the brackets like this? Any particular angle? Ive not yet welded on the coil over mounts or pan rod.
    Mechanic davemk1's Avatar
    Jul 2011
    herts
    525
    Re: 4 Link Bracket Help
    When I did mine gartrac told me to have the prop end of the diff pointing down a few degrees and weld the diamond brackets so you've got adjustment either way with the bars. I then welded the coilover brackets vertically from there by measuring the hole centres of the turrets and transfering onto the axle.
    Can't help with pan rod as I've got watts.
