Results 1 to 4 of 4
Thread: ESC and temp sender
    May 2019
    Finland
    ESC and temp sender
    Simple question regarding Zetec silvertop (hopefully sometime) running on a 91... ESC module. Which of the two senders in the Zetec thermostatic valve housing do I hook up to the ESC? The smaller, 1/8 NPT or so pointing downwards or the larger thread one on top?
    May 2019
    Finland
    Re: ESC and temp sender
    Quote Originally Posted by w9816 View Post
    ...I guess the most obvious answer would be "use the sender off the car the ESC came from" but I have not been able to figure that one out either!
    3,242
    They look to both be two wire sensors that seem to differ as before and after thermostat - so would be equally of use depending on the ECU response curve required? The std. ECU hook up may have comparator circuits that use both inputs?
  4. The Following User Says Thank You to katana For This Useful Post:
  5. #4
    May 2019
    Finland
    Both are two wire sensors with somewhat different characteristics. One is 41 Kohm at room temperature, the other one 900 Ohm. But as I said, it may be that neither of them is actually correct for the ESC, it being out of another car.
Tags for this Thread
