Results 1 to 4 of 4
Thread: Carb to manifold stud thread size.
    Bodger Richb77's Avatar
    Jan 2018
    Outside Berlin, formerly Newmarket Suffolk
    22
    Im bloody useless with imperial threads and guess thats what i have here.
    I have an Aluminium inlet manifold (no idea what from but its a Ford one) but no studs to hold the carb. Im not overly worried about the studs through the carb but what thread is in the inlet manifold?
    3,239
    Re: Carb to manifold stud thread size.
    Not much to go on ! If it definitely isn't M8 metric then it could be 5/16" either UNF or UNC................but could be bigger @ 3/8"
    Jan 2018
    22
    I wanted to challenge you all 😁.
    Ill measure them to find out.
    9,204
    if not metric then it will be 5/16 unc in manifold with the threads holding down carb being 5/16 unf.
    https://www.ebay.co.uk/itm/WEBER-DCO...YAAOSwSzdXDUVZ
    if metric then both m8.
    seller above will supply any combo or type
