So, after working on my axle to ensure it is dead centered so I can fit as wide tyres/wheels possible, with drive shafts removed, I observed that the splines that go into the diff are starting to twist!
I believe my only option is to go to uprated shafts and diff with 18 tooth side gears?
What power are these good to?
Who would you recommend? Which manufacturer?
On top of that, does anyone have the specs/length for a MK1 Cortina axle/drive shafts please as I believe they are shorter than the Escorts (They should be because that's why I fitted it!)
Many thanks guys
