Locating Pin and Gearbox Mount Bolt
Hi, few issues as below, comments please.
Locating pin
I gather the locating pin for the lowering blocks is not a part you can buy from likes of Burton etc? What do people use? Mine are non existent! As are the iso packs, which I read on here, most bin anyway. I'm running 2" blocks, they have shifted a bit lately.
Mount Bolt
This is not correct is it? On my type 9, the circular plate on the mount, bottom of box can rotate. The gearbox sits low, hoping the previous owner has used an incorrect length of bolt and its bottomed out. Anyone know the correct size/pitch/length of bolt or where you can get one? Or can I just remove the bolt and space it out with washers?
Cheers, Al
