Results 1 to 8 of 8
Thread: Lotus twincam - quaife rocket
    Dec 2017
    20
    Hi ,
    i have an escort mk1 ( mexico ) with a lotus twincam engine .
    the gearbox is a quaife rocket straight cut .
    which axle ratio would be the best for this setup ?
    it is a fast road car .
    25,110
    Re: Lotus twincam - quaife rocket
    it depends on what your after a 3.54 diff will make first gear go forever and make it difficult to get off the line, not very nice in traffic or do a hill start or something, at the other end of the scale a 4.4 will make it easy to /keep on cam/accelerate like hell, but scream its nuts off on a motorway. a 3.7 or 3.9 might not be a bad compromise for road use
    Dec 2017
    20
    hi , i believe i am running a 3.9:1 now .
    the wheels are 13" . The top speed of the car is a bit to low . Maybe i will change the gearbox to a 5 speed .
    would it make a big difference buying wheels 60r instead of 50r ?
    Mar 2012
    2,118
    For road use, you need a 5 speed. For sure, not a straight cut box. It will scream all day long. Usual standard 5 speed is all you need, will work fine with 3,9
    25,110
    5 speed will make a bigger difference than changing tyres
    Dec 2017
    20
    Would the t9 gearbox scream in 5th ? My rocket box now runs fine ( quiet ) in 4th gear .
    Of course this is 1-1 gear .
    25,110
    a standard T9 wont, one with straight cut gears will
    3,237
    I think 'scream' is the wrong word to describe a straight cut box - whine is better and should be noticeable even if box is fresh. With either a Rocket gearset / type E box or a T9 box - 4th is 1:1, 5th is overdrive 0.82:1 so overall revs will drop and be more 'relaxed' in top gear but the low 1st is a pain with a 3.9:1 diff - changing that for a taller 1st would make sense.
