Does anyone have a rough drawing/guide how to set up a 24 volt starting system on a car? bearing in mind the alternator is 12v, how do you charge just the main battery, and not both of them?
Reason i ask is, my car HAS to use a Escos Starter motor, but no-one seems to do a high torque one, so my car wont start as the voltage drop to the ecu wont fire the injectors unless the plugs are out!
i know mk1gaz had it on his blue escort....
any help would be great.
