Results 1 to 6 of 6
Thread: 1.4 efi escort van conversion to rs turbo help help help :)
    Jan 2011
    nottingham
    hi all help is needed. hi have a 1.4 escort van EFI is it posable to fit a turbo EFI in to the van and use ecu from the 1.4 ?? i have been looking at all electric plugs and they appear to be the same i think it will run BUT COULD BE WRONG ( PLEASE HELP) THANKS ALL
    Mechanic helinelly's Avatar
    May 2010
    merseyside
    710
    Re: 1.4 efi escort van conversion to rs turbo help help help :)
    hi there it would be better to just get the 1600 cvh and use the fiesta rs ecu....or rs turbo 1600...or is it your age for insurance........to be honest the 1.4cvh is dank...in the long run you will want to ditch the 1.4 anyways.regards nel
    Jan 2011
    nottingham
    hi there do you mean the 1.6 cvh efi turbo ??? iv got a 1.6 cvh efi escort rs turbo engine and it looks the same as the 1.4 efi engine thats in the van now if i take the 1.4 out and put the 1.6 in it will all plug in and all pipe up but will the ecu from the 1.4 run the 1.6 turbo??? my van is a w reg 2000 model and if i use the fiesta ecu will that plug in or will i need a converter plug?????? insurance is not a problem thanks nel
    May 2010
    merseyside
    710
    answer to your question is no matey........the 1.4 ecu is not really wireable....u will need an rs turbo ecu.....ether fiesta or escort turbo type.....you could buy a universal plug and play ecu for more pennys............................not really up on the turbo ecu's but looked around and found most info...kind regards nel
    Jan 2011
    nottingham
    could i use my loom or would that have to go as well???? if its ok to use the loom will a s1/2 ecu plug in it my loom but remember mine is a 2000 w reg modle or wood it be easer just to go for a non efi turbo ???
    Tyre Kicker xr22rs's Avatar
    Jan 2011
    Holland
    17
    Escort and FRST are two different things only the fiesta has EFI the Escort has a metering system regulated by airflow
    See other thread
