Page 2 of 2 FirstFirst 1 2
Results 41 to 77 of 77
Thread: Pinto turbo bottom end build
  1. #41
    Mar 2014
    Glasgow
    61
    Re: Pinto turbo bottom end build
    Managed to cc the head today using the perspex method and pretty confident the chambers are bang on 50cc. Will need to get the block back with the pistons to measure the piston height from the deck and the cc of the piston bowl. Plug in the numbers to an online calc and see what i need to be. I will try different combustion chamber cc’s till i get the desired comp ratio, fill the chamber up with the cc of fluid and measure from the surface to the fluid and that should give me what needs to be skimmed.
    How accurate i can do all that will be a bit of a hit or miss lol but sounds gd in theory?
  2. #42
    Mar 2014
    Glasgow
    61
    Car is back up and running. The calculations i have done after skimming 1mm off the head seem to have me at about 8.3:1
  3. The Following User Says Thank You to Turbo_crossflow For This Useful Post:
  4. #43
    Mar 2014
    Glasgow
    61
    Got my setup all up and running, Ended up taking 40 thou off the head and recon i’m running about 8.3:1 comp. Got a set of ev14 550cc injectors which have made the car so much better and easier to tune than the old ev1’s!
    Only problem now is what clutch do I fit for the power but still drivable for road use? I have an LUK heavy duty at the moment and its slipping in the higher gears on boost.
    Greg
  5. The Following User Says Thank You to Turbo_crossflow For This Useful Post:
  6. #44
    Mar 2012
    Shropshire
    407
    I have a paddle clutch in mine, works nicely and pretty friendly on the road, though not sure if the car being so light helps.
  7. #45
    Nov 2004
    Sweden
    1,167
    I think you can search a bit in my old posts about my experiences and thoughts of Pinto turbo clutches.
    I have choosen to use a YB 240 mm size, that means there are some other options available. Currently I'm on a Sachs 695 clutch cover and an AP organic disc. I have used a 6 paddle sprung plate earlier but prefer the organic one, lot's easier to drive.
    But going to 240 mm means other changes (bellhousing, gearbox, starter) too. I ran out of working, driveable 215 mm options though.
    Gustaf
  8. #46
    Mar 2014
    Glasgow
    61
    Mine in a sierra so a tad heavier lol. What paddle clutch do you run tho?
    Gustaf, do i really need to be changing to a yb clutch? From my searches i can see that yb flywheel wont fit my pinto crank. I’m running an mt75 box on my pinto, would this work with a bigger flywheel? Can the pinto wheel be drilled to suit yb clutch or is it too small?
    Thanks guys!
  9. #47
    Mar 2012
    Shropshire
    407
    Thats a good question. It was an ex display item from a company that had shut down, so details were sketchy, but it was cheap so.... If memory serves, it was a borg & beck item, but I was never able to find the details of a borg & beck paddle clutch for a pinto, so who knows?
  10. #48
    Quote Originally Posted by Turbo_crossflow View Post
    Thanks guys!
    I have heard it mentioned you need a transit flywheel which is big enough and is the same crank bolt pattern to the pinto crank. Maybe a load of rubbish as well though.
  11. #49
    25,110
    Correct Transit pinto flywheel is same bolt pattern as normal pinto, but bigger dia
  12. #50
    Mar 2014
    Glasgow
    61
    Ah yes brilliant i see the transit pinto uses a 240mm clutch, next problem is will it fit my mt75 bellhousing
    Did some cossies not use the mt75 box?
  13. #51
    Mar 2014
    Glasgow
    61
  14. #52
    Aug 2019
    Holland
    i dont know for sure about then and now. But i had run such a cam ( crossdrilled as you say ) back in the days, it was an oval hotrod profile and it worked very good that way. Why shouldnt it be practised nowadays?
  15. #53
    Mar 2014
    Glasgow
    61
    Sorry dont know why that double posted, it seems i need to either machine down the transit flywheel to fit the smaller ring gear of buy a 4x4 mt75 box and swap the back end of the box with my 2wd part. I think the machining option sounds best lol
  16. #54
    Mar 2012
    Shropshire
    407
    if machine the flywheel down to take a smaller ring gear, wont that defeat the purpose of the larger flywheel?
  17. #55
    Mar 2014
    Glasgow
    61
    I dont know the size difference yet but obv as you say, if it needs to be turned down smaller than the diameter of the 240 clutch then yep thats no use lol
  18. #56
    2,656
    267
    Quote Originally Posted by theduck View Post
    Depends on how much it has to be machined down really. The main objective is to be able to mount a larger diameter clutch on it, so as long as it's not machined down past the clutch mounting holes it shouldn't be a problem.
  19. #57
    2,656
    267
    Just realised I hadn't seen this when I replied.
  20. #58
    Mar 2014
    Glasgow
    61
    Think your right duck and rallyrob, done some measuring and looks like my only options are either t5 box or mt75 4x4 box and build a hybrid using my 2wd box. Another thing that has me puzzled tho, how do these bigger bellhousing boxes still fit to a 205 block cossie if a 205 pinto is basically the same thing or are the lugs wider perhaps?
  21. #59
    2,656
    267
    The T5 and Type 9 bellhousings are just a slightly different shape around the block/bellhousing mountings holes allowing for the bigger or smaller diameter flywheels.
  22. #60
    Yep the bolt holes for a rs2000 bellhousing bolt on the outside as it is a lot smaller. T5 sort of bolts on the inside if that makes sense. T5 is massive compared to the rs one.
    I have a pinto, cosworth and transit flywheel and can measure them if you need at the weekend.
  23. #61
  24. #62
    Mar 2014
    Glasgow
    61
    Thanks Dave, i think from what i have gathered, the transit o/d is 335mm. Would be interesting to see also if the cosworth flywheel holes for the clutch cover use the same hole pattern. If its unique to the transit flywheel this would mean i’m restricted to transit cover plates.
    If you could check what the transit flywheel would look like shaved down to the std pinto ring gear size in relation to the cover plate holes too that would prob be the decider
    Cheers Greg
  25. #63
    Mar 2014
    Glasgow
    61
    Cheers Greg
  26. #64
    I will try and get some pics of them. I was told it was a transit flywheel when i was sold it by mistake as a pinto flywheel.
  27. #65
    Nov 2004
    Sweden
    1,167
    I have friends who have used the DOHC "small" MT-75 on YB's, and they report of minor grinding and modifications to the starter mounting.
    On the other hand, the 2.3 16v (and possibly 2.0 16v too) frog-eye Scorpio has an MT-75 and a 240 mm clutch, that should be a direct fit. Hydraulic throwout bearing too, nice! I have one as a backup for my T5.
    As for flywheel, I had TTV make me a steel YB flywheel with a Pinto bolt patter. It is now 10 years ago but it was way cheaper than I feared.
    Gustaf
  28. #66
    Mar 2014
    Glasgow
    61
    Clint from bhp says this https://shopbhp.com/collections/heli...-rally-version should do the job on the standard pinto flywheel. May save a bit of bodging and butchering :-/
  29. #67
    Mechanic snapper1's Avatar
    Oct 2010
    Chelmsford
    67
    668
    27
    Did you find a Cosworth oil pump and pickup with spray bar?
    I found one in my pile of bits.
    What I did on my Pinto build was to take the Cosworth pump top off and put it on a high pressure oil pump, then grafted the oil spray bit to an RS2000 pickup to match my sump.
  30. #68
    Nov 2004
    Sweden
    1,167
    I can't find a torque rating for the Helix clutch kit, that's nice to have in order to say if it's likely to work or not.
    Anything less than a 300-350 Nm torque specification is marginal on a Pinto turbo IME. At least long term.
    Gustaf
  31. #69
    Mar 2014
    Glasgow
    61
    Snapper, yes i got a spray bar setup sorted, just used new standard pinto oil pump with cosworth top cover, wasnt sure if high pressure would blow my turbo seals.
    Still haven't done anything about the clutch yet. Insurance has ran out on the car now so prob just keep it off the road for the winter and give the spending a rest for a bit lol.
    Diff will need rebuilt also as its a bit noisy on light load and also the lsd system needs repacked. Dont know what to do for management side of things either as finding someone in Scotland or anywhere at all that can do megasquirt seems a bit tricky. Should prob invest in a decent management system now that Ive spent a few bob on this rebuild. Theres also the camshaft too, still running standard efi and not sure if a turbo profile would be better b4 amy mapping gets done? Things going like stink at 1.2bar at the moment but needs setup proper.
    Anyway back to saving again lol
    Thanks for all the help on here guys!
  32. #70
    Mar 2012
    Shropshire
    407
    I had a custom cam profile done for mine, i'm sure it wasnt needed for my power goals, but it felt like one of those things I should do while we were at it.
    As for management, I have mine on megasquirt2 still, it does everything I need. Though I can tune it myself and have access to a friends dyno and his guidance on any tuning issues I'm not sure on. Have to say he was a tuner not convinced by megasquirt until he played with mine, he had only experienced megasquirt 1 and thought they were all the same. Unfortunately, in the UK atleast, it seems the MS1 has tarnished the megasquirt name for good.
  33. #71
    Mar 2014
    Glasgow
    61
    Update on my pinto!
    Got a helix 4 paddle cerametallic clutch now and quite surprised how decent it still is to drive as a road car with this!
    Had the car in for mapping yesterday, was told my fuel pump was running out of puff but managed to make 230hp at 1.2 bar. Broke the standard cossie power barrier so chuffed with that!
    The tuner wasnt too familiar with the idle settings on my megasquirt 2 tho so still need to battle with that. My idle is fairly stable but need to get fan/headlights etc compensation dialled in.
    New fuel pump will be next on the list :-)
  34. #72
    Mar 2012
    Shropshire
    407
    What fuel pump are you using?
    Power seems low for 1.2 bar.
  35. #73
    25,110
    standard pinto power is 100bhp, so given a bar of boost on a standard engine you would expect 200, so 230 doesnt sound so bad to me
  36. #74
    Mar 2014
    Glasgow
    61
    My sierra has an in tank pump, im using a standard pump for a focus rs but it was off ebay and prob crap quality tbh. Thinking going bosch escort cos in tank pump now.
    i’m still running stock cam and dont have any head porting work etc done
  37. #75
    Mar 2012
    Shropshire
    407
    Was just thinking on mine, which is similar spec bottom end, I was making 300 at 20psi, but was forgetting my head has big valves, cam, ported etc.
    The walbro 255lph pumps are good, gss342 I think is the proper model number. Like everything though there are loads of fakes around now so best buying from someone you know will only be selling genuine products.
  38. #76
    Mar 2014
    Glasgow
    61
    Fuel pumps on back burner, just wrecked two alloys and tyres on a pothole ��
  39. #77
    Mar 2014
    Glasgow
    61
    Bosch escort grp a in tank pump fitted now, need to reduce some fuel now from top of ve table or get it back in for mapping again
