Results 1 to 4 of 4
Thread: ecu
    Jan 2011
    nottingham
    ecu
    hi all can anyone tell me if you can use a 1.4 efi loom and a rs turbo ecu together (will the rs turbo ecu plug straight in to the 1.4 loom) i have a 1.4 efi escort and i want to take the engine out and out a turbo efi in its place can anyone help please
    Tyre Kicker xr22rs's Avatar
    Jan 2011
    Holland
    17
    Re: ecu
    This is not possible you will need the motor management loom of a FRST also there are 2 type's of ECU OFAB and OFAC .
    You will need the loom and ECU to match it is possible to modify the loom to match the type of ECU you are using.
    But i would try to buy a set .
    If you need more info about modifying the loom i can get it for you.
    Good luck
    Jan 2011
    nottingham
    Re: ecu
    hi mate thanks for that if you can get me that info it would be really helpful (god dam mk6 escort i new i should i got a mk3/4 would have been a lot easier) lol
    Jan 2011
    Holland
    17
    Re: ecu
    Have a look on this site
    http://www.fiestaturbo.com/forums/gu...anges-vt77331/
    If you have any further problems let me know.
