Leaking Girling hydraulic fluid Reservoir
Has anyone had trouble with a leaking hydraulic fluid reservoir on a mk1 escort? I think its leaking between the hose and pot causing fluid to drip all over the bulkhead.
I'm guessing you can use some kind of sealant?
Link to pot below
https://www.ebay.co.uk/itm/Mk1-Escor...-/172229327562
Re: Leaking Girling hydraulic fluid Reservoir
sealant + brakes = NO
probably the hoses are old and hard, try new hoses or just shortening them slightly and useing a new clip
I used the same ones as per the link. I replaced them around 6 months ago and they have been fine up till now, so unsure why it has started leaking
