Page 6 of 6 FirstFirst 1 2 3 4 5 6
Results 201 to 218 of 218
Thread: pete a 2.2 200 and a bit bhp pinto
  1. #201
    3,641
    Re: pete a 2.2 200 and a bit bhp pinto
    The afr scale could do with being shortened....it seems to run rich around the two dips....12.2:1 although the graph scale makes it look worse than it actually is.
  2. #202
    Mar 2012
    2,118
    I can show hundreds of power graphs and if it is a race engine, always dips and bumps. The small once you can never get rid off. With a bit of luck you can place them to other points by making the inlet track shorter or longer, playing with the exhaust 4-2-1 configuration etc... Only with relative soft cams you can get a nice ballon curve. But it's because softer cams have less of these things, the best cam will be the soft one.
    Indeed, these small dips are not noticed while driving. But when the engine is long in low torque round 3000 RPM and it's a rally engine, it will feel smoother in short situations. I'm always concerned about the whole graph, not peak power only.
  3. #203
    4,875
    Well that's good because you don't have to be because it's not yours!!
    Thank God for that !
    That's what I mean.
    248 Kw, this is not a Pinto I guess ?
    The power is on the left axis so almost 150 kW, torque is on the right axis almost 240 Nm.
  4. #204
    Jan 2009
    Germany
    428
    150KW / 240Nm I can not believe. This has no harmony in the calculation.
  5. #205
    25,099
    Quote Originally Posted by Escort TC View Post
    thats not the engine this thread is about anyway
  6. #206
    3,641
    Question - how do these long stroke pinto's rev compared to a square or over square unit??
  7. #207
    25,099
    its got an 80mm stroke on emeralds rollers it was pulling like a train to 7500.
    andy pipes which has an 86mm stroke and whilst it dont make any real power at such revs pulled smoothly round to 8700 on T+R's rollers, on track he is revving it to 8 all the time
    rev wise the longer stroke doesnt seem to notice in either,
    both have longer than std rods, although not massively, cant remember the length of 1600 diesel rods in the 2.2 but they are about 129mm, and andys has custom steel 131.5mm rods
  8. The Following 2 Users Say Thank You to Graham For This Useful Post:
  9. #208
    Mar 2003
    Now over the pond North side
    3,540
    it is on throttle bodies, i must admit those graphs look so messy i cant see a mixture on them!
    As Graham said, it is on throttle bodies. Short 42mm Jenveys I think
    This might help Graham
    peaks and dips can usually BUT NOT always be mapped out, ive run enough race cars on the rollers to know that its not always possible, if teh primary cause is teh mixture going off at that point then yes to a point, but if its because of a "bad" intake length, or perhaps pulse in the induction caused by say an inner wing or air box, or maybe even exhaust design, you might correct the mixture, you might smooth it out with a timing adjust, but if at those points there simply isnt as much air getting into the combustion chambers you are going to get a dip no matter what the mapper does.
    Both places I got it mapped both said the same thing, ref they thought it might be the exhaust system
    i bet one thing for sure dazzle wont feel it when he drives the car !
    At last, a worthwhile relevant statement and true
    it pulled so quickly through the dip you never knew it was there.
    which is the same as above. Mines not a race car but I've never noticed it, thanks Graham
    Dazzle
  10. The Following User Says Thank You to dazzle For This Useful Post:
  11. #209
    Mar 2003
    3,540
    So, I thought I would put these up....
    The setup belongs to my friend who I might be joining/investing in his business
    It's a DYNOmite hub dyno which has the ability to hold at set rev's and map for different load sites. An accurate good piece of kit.
    That was with the Airbox
    This was the glory run at the end with the airbox removed so you could hear it in full glory
    Dazzle
  12. #210
    25,099
    cool,
    power at the wheels was still same as when it was on rollers over here so you havnt worn it out yet
  13. #211
    Mar 2003
    3,540
    Probably even better due to the difference in altitude levels!?
    Was expecting it to be less so was pleased with that result
    Dazzle
  14. #212
    Aug 2006
    Christchurch, New Zealand
    463
    Top Job lads What was the reason for the coolant pressurising?
    There's a wee write up on this engine on the Emerald website: http://www.emeraldm3d.com/articles/oct2011/
  15. #213
    Jun 2015
    Australia
    289
    hi graham is 40 hp loss through drive train correct here in australia we think 30 hp loss is more correct your ideas cheers mario.
  16. #214
    25,099
    depends on how much power it makes in the first place, not to mention whether rollers are single or twin, narrow tyres or wide sticky slicks, loosing 40bhp off 200 is 20%
  17. #215
    Apr 2013
    S Wales
    230
    431
    Re: pete a 2.2 pinto
    diesel rod next to a very similar looking x/flow rod
    big ends are 1mm too wide to fit a pinto crank so i made a jig to narrow them in the lathe
    diesel rods are a little on the heavy side so i've started to lighten them a bit, first remove the big balencing pad from the small end
    Hi Graham,
    Bit of a resurrection of an old thread, but I'd like to ask you a question regarding the big end side of the diesel conrod and it's bearings. I understand that the big end is about 1mm too wide and has to be machined smaller, but what's the score with the bearings. Do the new bearings that go with the diesel rods also need to be made smaller on their width, or do they still fit OK straight out of the box?
    Thank you in advance for your advice.
  18. #216
    25,099
    bearings are ok straight out the box. you cant get 1600 diesel bearings any more though, but you can use 1800 ones, the only difference is 1800 ones dont have location tags, but they will work just fine
  19. The Following User Says Thank You to Graham For This Useful Post:
  20. #217
    Apr 2013
    S Wales
    230
    431
    Thank you for the prompt reply and advice.
    I've been lucky and sourced 8 rods (2 sets) and new sealed 1.6D bearings with the tabs. Click image for larger version Name:	IMG_20180618_201419702~01~01.jpg Views:	149 Size:	128.2 KB ID:	82881
  21. #218
    Apr 2013
    S Wales
    230
    431
    Click image for larger version Name:	IMG_20180504_152621342~01.jpg Views:	148 Size:	123.5 KB ID:	82882
    I was a bit greedy and couldn't resist buying the second set. ��
