Page 2 of 2 FirstFirst 1 2
Results 41 to 63 of 63
Thread: My MK2 Escort. Soon to be 20v
  1. #41
    Mechanic Mk1_Deano's Avatar
    Mar 2007
    Maidstone
    33
    554
    9
    Re: My MK2 Escort. Soon to be 20v
    Great write up on the conversion mate, neat, tidy but best of all the car remains pretty much standard on the outside
    Quote Originally Posted by bunta20v View Post
    When I decided to go the 20v route, I asked for help and advice of someone whose 20v 4age escort is very well known on this and another site and basically got fuck all from them. Not even a reply. I vowed I wouldn't do the same and attempt to share good solid info. Hopefully somebody benefits from it.
    Well least you found someone that did reply then
    Keep up the good work and the updates coming
  2. #42
    Dan's Avatar
    Aug 2006
    north london
    4,378
    115
    love this project, its looks properly at home in there, really neat
    thanks for taking the time to post everything up, i know it can be a pain in the arse but its invaluable for anyone wanting to do the same conversion
  3. #43
    Jan 2011
    Sarf Rugeley
    584
    32
    Quote Originally Posted by steely dan View Post
    No probs and thanks for the comments guys. More pics to come
  4. #44
    Jan 2011
    Sarf Rugeley
    584
    32
    RH side chassis mount
    Last three pics show the where the type 9 bolts up to the floor. For this I cut up the original crossflow engine mount into 2 pieces. Drilled the 4 holes and bolted it up then welded the nuts to the plates and cut the bolts flush. If I need to remove the gearbox in the future, I dont need to take the carpet up and works like a stock factory setup.
    Apart from water and ignition, the sump is a major stumbling block to getting this engine working in a Escort. Contrary to belief, you don't need to convert it to a rear sump setup. The sump on a 20v was designed pretty damn well from the factory and only needs minimal cutting and welding to work in a escort. I managed to keep the factory baffle so I simply make sure the oil is on the full level on the dipstick.
    I wanted to get my temp gauge working so everything worked as it should do so bought a new temp sender and an adapter to fit into the water kit. A bit PTFE tape was used to stop any water leaks.
    Final thing to get working was the rev counter. The omex ecu does have a tacho output but it wont drive the older coil rev counters like the escort so used a £4 circuit to run the signal from both - sides of the new coil pack.
    http://www.turbosport.co.uk/showthre...k2+rev+counter
  5. #45
    Nov 2003
    Wirral UK
    6,740
    257
    Nice update there mate
    http://escort.accelerator.org
  6. The Following User Says Thank You to exboyracer For This Useful Post:
  7. #46
    Mechanic mk2-mad-ad's Avatar
    Nov 2008
    stoke
    644
    25
    hi mate that looks really well in there nice work how much do you think its all cost to do ??
  8. The Following User Says Thank You to mk2-mad-ad For This Useful Post:
  9. #47
    Jan 2011
    Sarf Rugeley
    584
    32
    Quote Originally Posted by mk2-mad-ad View Post
    Thanks. As I decided to go for aftermarket management it added another £1100 to the balance but below shows what it's cost so far
    Engine - free
    Type 9 box £100
    Quick shift £60
    Bellhousing £280
    Clutch, Release bearing and pilot bearing £90
    Starter motor £30
    Engine mounts £100
    Clutch and accelerator cables £25
    X-Flow system £100
    4age manifold £200
    Fuel pump £40
    Copper pipe £20
    Omex management kit £1100
    Water kit £240
    HTH
  10. #48
    Norwich
    500
    17
    I know a company that does an off the shelf kit for 20v same money as omex and will come with a proper map
    They do plug and play for Vw s , but I have uses a couple of kits that have all the relays included in loom and just require 3 or 4 wires joining
  11. #49
    Mar 2007
    Maidstone
    33
    554
    9
    Great update mate Now I'd better pull my finger out and get mine done! Still need some vids though
  12. #50
    Apr 2004
    Bangkok, Thailand, Thailand
    4,346
    479
    Looking gooood.... We deffo need a video when this thing is up and running
  13. #51
    Jan 2011
    Sarf Rugeley
    584
    32
    Quote Originally Posted by Mk1mexcos View Post
    Sounds similar to the kit RAW engineering does then. They supplied a full kit and a 160hp map all included in the price. They also include setup time down there too which worked well. Always good to see other companys supporting the 4age.
  14. #52
    Jan 2011
    Sarf Rugeley
    584
    32
    Quote Originally Posted by Mk1_Deano View Post
    Get busy with that welder m8. Youre 20v Escort is well overdue
    You made any progress yet? Will try and get videos up over the weekend
  15. #53
    Mar 2007
    Maidstone
    33
    554
    9
    Slowly making progress mate, almost welded up the entire front o/s, floorpan, splash panel and strut top done, just got the suspension cup to do then its onto the n/s. Will update my thread soon
    This thread is useless without videos btw
  16. #54
    Jan 2011
    Sarf Rugeley
    584
    32
    Lol I luv the agro your dishing out over the videos. I will definitely get some up on here and was meant to do them this weekend.
    Just a few pictures of the modified prop. Now the intention was just to make a temporary prop then eventually replace it with a single piece when time and money permits however this one has taken some stick and it aint broke yet so long may it continue. (touch wood)
    Had a go at cleaning up the mexico steels after reading a thread on here.
    http://www.turbosport.co.uk/showthre...t=steel+wheels
    Think they scrubbed up ok but what a tedious job. Used about 5 different primers before the top coat but for a first time job at home it worked. Had them done just in time for the classic ford show.
    My youngest child Megan at the wheel. Gots to teach the kids early on about real cars.
    My car makes the pages of Retro Ford.
  17. The Following User Says Thank You to bunta20v For This Useful Post:
  18. #55
    Apr 2004
    4,346
    479
    Nice one with the feature!
    The devil car
  19. #56
    Jun 2011
    Vic, Australia
    Congratulations on getting a feature in a magazine, do you mind if I use those pics for my site?
    What was the name of the magazine?
    Custom 4AGE 20V conversion parts:
    S-86.com
  20. #57
    Jan 2011
    Sarf Rugeley
    584
    32
    Quote Originally Posted by Sam-Q View Post
    Hi Sam,
    Yes m8 it's fine to use the photos. It's this months edition of Retro Ford magazine. your company is mentioned in the article so some free advertising regarding the water relocation kit.
  21. #58
    Jun 2011
    Vic, Australia
    I saw that aft6er I zoomed in, thanks I will put it on my customers car page
    S-86.com
  22. #59
    Jun 2011
    Vic, Australia
    I am going to order a mag, could you confirm what issue number it is? thanks
    S-86.com
  23. #60
    Jun 2011
    Vic, Australia
    is it "Retro Ford - Back Issue -November 2012" ? I know it's issue 80
    S-86.com
  24. #61
    Jan 2011
    Sarf Rugeley
    584
    32
    That's the one Sam.
  25. #62
    Jun 2009
    coventry
    First fit up of the 4age in the bay.
    This is the original starter solenoid which is no longer needed. 2 red thick wires normally go to the battery and starter motor. Red/Black wire is your ignition start, Yellow/Black goes to the coil when starting. With a 4age starter simply connect the exciter wire to the black/red wire and thick wire from the starter straight to the battery. Remove the rest.
    These 3 wires are from the crossflow alternator. The 2 red thick wires are not needed. The blue wire is the alternator charge lamp.
    Probably my favourite picture of all. Taken at the end of the first day of the swap.
    Hi mate. Fitting zetec in my mk2 and been trying to figure out wiring to alternator. You said u dont need the two red wires do I just cut them off and attach them to nothing. And just pull a new wire from battery to new alternator and connect blue wire to alternator. Where do the two red wires go too as I thought they should go to battery but don't. As I have ripped all the old solenoid and starter out the only current wire I have to battery is a small brown one which feeds my fuse board and ignition.
  26. #63
    Jun 2020
    North Wales
    Hi sorry to drag an old post up but,
    Id like some info on the wiring and ecu kit
    And where to get a front trigger wheel and crank sensor mount thanks
