How to remove m16 pistons without air?
Can anyone suggest a way to get the pistons out of my m16 halves? Because they are apart air is no good. They are pretty rusty but where not seized when I split them.
They are also fully in. No lip is available for pullers.
Re: How to remove m16 pistons without air?
I used air recently on some sierra rear calipers and worked a treat, i would reassemble and try air. You probably won't need 100% seal.
weld something to the piston to pull with some molegrips
fit a grease nipple to the pipe connection and use a grease gun to pump grease in, works a treat
