Hi! I ‘m restoring my old Cortina and now I am going to rebuild my Pinto engine, specs so far are:
V6 Pistons
Head flowed with 45,5 inlet and 38,1 exhaust valves
Kent FR 32 kit
YB Cosworth rods
high pressure oil pump
4-2-1 exhaust manifold
free flow exhaust
Twin Weber DCOE 45s with 38mm chokes
Fast Road vacuumless distributor
T9 GearBox and 4,1 final gear
I m thinking about to change FR32 camshaft with Kent GTS1 , has anyone ever tried it with similar engine spec?
what power output should I expect?
my rev limiter will be set at 7000 rpm
does anyone has any Dynos chart of a pinto withGTS 1 camshaft?
what is your opinion?
Car is for road use and this is the reason that I am trying to choose a camshaft between FR32 and GTS1
