Fitting tramp bars to my Mk2, so tacked the chassis brackets in place dropped the car on the floor and tacked the axle brackets in slightly forward @ 11 o clock position, removed the bolt and sent the car back up on the ramp.
Now there is no way you could get the bolts back in they are nearly a hole out once the car is back at ride height you can get them in.
Is this normal? It sounds like a lot of load on these points if you take the weight of the car.
