hi all,
Been reading on her alot for some time been massive help thanks. I thought i put up a post of my conversion, i have done everything to the car myself including the crappy spray job what will be re done when i have the cash. when i got the car it was a rot box, it had new wings both sides, one rear wing, rear lower panel and cut alot of rust out and filed with new metal. Also had 2nd hand rust free doors, bonnet, boot, sunroof, and even the filler cap. Well i went for the zetec conversion as i have done a few in the past but only in mk2 xr2's so this is my 1st rwd one. From the start i wanted to save as much money as i can by making most things myself so on went the coversion after the body was all ready for it so this is how i have done it so far.
1st thing was to find a engine, and with the help of the bay i found one for a good price from a kit car that the guy had given up on lol always the way. and to go with it he had a lightened fly wheel that had been drilled for a pinto clutch, and he had that too so i got all that off him and took it to my work shop where i cleaned and gave it a lick of paint.
pleased with that i set about making my own water rail. I had the idea of getting a pinto stat and cutting the end of and getting a mate of mine to alloy tig weld a peace of alloy 32mm pipe on to it, doint this allowed me to use the pinto stat. Then i made the back part from steel and mig welded it all together with a out let for the heater and tapped a hole for the temp sensor.
Once i was happy with that i mated it up with the gear box and droped it into the engine bay where after a few hours making it sit right i could make up some mounts. i went with the DIY kit from retro ford to save some time making wise, and also is a have to for the capri really.
(sorry for the crap pictures)
Now with the engine in and mounted i can start bolting on new shiny stuff such as cam belt kit and new studds ready for the manifolds, also i bought the retro for alt kit (so much for saving money).
Next after a few head aches i put the rad in and started the plumbing, this i made myself out of some 32mm steel tube and some old hose's i had floating about. Also i put the starter in at this time sorry no pics of that.
Well got alot more to do, but as with most things the only thing slowing me down is money, next thing i be doing is making a mount for the coil pack and also putting on a inlet manifold and bolting up a 38 dgas carb to it and then come the head ache of wiring lol.
thanks for looking will keep updating this for every one.
