That is 373.9 BHP, what spec and boost are you running?
Engine Spec
205 block, custom made pistons 7.5:1 comp, 5.5 inch long rods,std crank doweled to steel flywheel. Head has group one valves, ports cleaned up & inlarged crane 332b cam & ARP head studs. Turbo is a Trust td67 with external wastegate & E2 eletronic boost controler. Fuel & ignition is controlled by a EMS Stinger
The power comes in with some bang after 4600rpms up to 5900rpms or more. What is it like to drive?
blimey 435bhp, at your revving it to 7800rpm, never knew the pinto exhaust ports to flow that well!!!!!!!
also just noticed the torque figure so this printout is at the wheels, so you have 435bhp at the wheels
is this a drag car? what gearbox, axle, clutch etc are you using?
Hi.... Vizard was talking about 500hp pintos 30years ago & there have been a lot of improvements since & I know mine is not the most powerful out there.. I do have a post on here some where with engine specs if you cant find it I will put it up for you
Thanks Steve
