Hello All
Looking for some advice I have just about finished bolting a duratec (s/h 60k accident damaged mondeo) into my mk2 RS2 and all was going well. fired it up no problems other than high oil pressure 90ish cold 40 hot.
Then put her on the rolling road for a set up, again no real problems.
Now though after getting her back home every time i start it up on any thing more than tick over it blows the seal out of the oil filter.(twice) and it has buggerd the pressure gauge that went up to 100psi any sugestions? i'm running a wet sump (retro ford) and a race line filter adapter plate.
Reading various comments on here it seems that its not uncommon is it likely to be a stuck PRV or is it that the oil filter I'm using could be to small, its off a 1600 cvh its the only one that fits between the rail
regards
