Results 1 to 3 of 3
Thread: Rollover Spit
    Apr 2009
    Anglesey
    47
    11
    Rolleyes Rollover Spit
    I am trying to build my own spit to put my escort Mk2 on for restoration. Can someone please tell me what height the pivot point should be for the spit to ratate 360 degrees. Thanks
    glostershire
    240
    14
    Re: Rollover Spit
    If you make sure that your pivot point is in the center of you car, then if you Measure the width of you car, divide this by 2 and then add, say, 300mm to give a good ground clearance you should be ok
  3. The Following User Says Thank You to biffco For This Useful Post:
    Nov 2008
    Adelaide, Australia
    1,440
    98
    Re: Rollover Spit
    This has everything you need to know!!!!!!!
    http://www.neilfletcherracing.co.uk/the_spit.htm
    I made mine 42" which from memory is what it says in the link. I designed mine based on this link....slight differences.
  5. The Following User Says Thank You to MK1_Oz For This Useful Post:
