but i think i have fun with my engine.
on my Dyno. Starting at -20KW for the Plotter
and the Engine Bay
and the Engine Bay
Nice looking yb engine you have there
This needs to go into the power plot section
What are the bhp and torque values in bhp and lb/ft @flywheel
This is @ Flywheel
Revs KW NM BHP
3000 55 175 75
4000 88 210 120
4500 100 212 136
5000 123 235 167
5500 136 236 185
6000 149 237 203
6500 160 235 218
7000 168 229 228
7500 171 218 233
8000 170 203 231
sorry no lb/ft
lbft = Nm x 0.7 ; so 237 Nm = 166 lbft
Many Thanks, Leon.
Here now the Video on the RR
http://www.myvideo.de/watch/8405610/...e_Roller_Dayno
What cams are you using?
P.S.
No standart UK Cams. Make for me in Germany.
Are only for me and the engine had a few other modification. Sorry.
It was the 4. gear. About 3000 Revs as start. And i think wheelspin over the complete test but i cant see it on the sheet. The Car was very strong fixed with belts in the roller but you can see the action of the car.
The Engine hasnīt the Cosworth Valves and not the Diesel Buckets and other cheap bits. It has bigger Valve seats (thanks to Steve Curson) and much work. The block has new bored out and only about 20Km before tested as the old block was broken on the 2. cylinder. The next step is a Dry Sump system. I think then it will be a nice engine.
As reference my BDE
http://www.myvideo.de/watch/8414311/...he_Roller_Dyno
and the sheet
The first Engine have 50 DCOīs. Sorry , but i cant remember me who i have bough it. The Ram Pipe are push on type and i have shortend it.
